9 years agoAuto-negotiation failed in MAX 10 FPGA development kit
Hi, I'm using MAX 10 FPGA development kit (10M50DAF484C6GES). I am using the simple server socket example design (downloaded from altera design store) to test the ethernet ports. I changed the ...
9 years agoHi,
I used the project (which is available in board update portal of REV-C max 10 development board installation kit) also to test the ethernet port B. When I tried with already available .sof and .elf file Auto negotiation is passing. The recompiled design is working with existing .elf file but, when I try with the .elf file by creating application project for web_server (the source files which is available in the update portal project is used) is not working. It is displaying Auto-negotiation failed. Is there any settings I need to change to work with Port B. Thanks in advance.
