Mathiazhagan's avatar
Mathiazhagan
4 years ago
Auto increment address in the memory in a verilog program
Hi there,
Am a new learner in verilog, So please help me out how to resolve this issue
I have created a simple SRAM Module
I want to increment my address on posedge of every clock pulse, but i don't know how to do it, so anyone please help me out in resolving this issue
I have posted my verilog code too
module sramw(dataIn,dataOut,Addr,CE,WE,OE,RD,Clk,RST,//count
parameter ADR = 19;
parameter DAT = 8;
parameter DPTH = 524288;
//parameter COUNT = 19;
input [DAT-1:0] dataIn;
output reg [DAT-1:0] dataOut;
input [ADR-1:0] Addr;
input CE,
WE,
RD,
Clk,
RST,
OE;
//reg Addr
//internal variables
reg [DAT-1:0] SRAM [DPTH-1:0];
always @ (posedge Clk)
begin
if (CE == 1'b0) begin
if (WE == 1'b0 && RD == 1'b0) begin
SRAM [Addr] = dataIn;
end
else if (RD == 1'b1 && WE == 1'b1) begin
dataOut = SRAM [Addr];
end
else;
end
else;
end
endmodule
  • YEan's avatar
    YEan
    We do not receive any response from you to the previous question that have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
    Ean
  • YEan's avatar
    YEan
    Do you have any updates on your problem?
    Ean
    • Mathiazhagan's avatar
      Mathiazhagan
      Dear Ean,
      No, I did not get any update for this problem, I have tried but i could not solve the problem, could u please share me a sample code for the above mentioned problem, which will be very much useful for me to proceed further.
      Awaiting for your favorable response.
      With Regards,
      V.Mathiazhagan
      • YEan's avatar
        YEan
        The example provided by @ak6dn had shown the auto increment of address using always block.
  • ak6dn's avatar
    ak6dn
    Well, you haven't shown enough code.
    In your module definition Addr[ADR-1:0] is an input to the module and thus is a set of wires.
    In a higher level module that instantiates a call to sramw() you would probably have declared Addr[ADR-1:0] as a reg.
    And in that module you could do assignments to that reg variable, including incrementing it on a clock edge.
      Mathiazhagan
      Dear Sir/Madam,
      Yes as you mentioned the addr[ADR-1:0] has been assigned as input, but the input cannot be declared as a register right, then how to solve the issue.
      On a condition @ every posedge clk my address should get auto incremented and in that auto incremented address i have to store some value.
      If possible could u please share me a code for this ,Which will be very much useful for me to proceed further.
      With Regards,
      V.Mathiazhagan
      • ak6dn's avatar
        ak6dn
        You still need to write the upper level module code that instantiates your sramw module instance.
        It would have pieces of code that look something like this:
        module TEST;
        localparam ADR = 9;
        reg clk;
        reg [ADR-1:0] addr;
        always @(posedge clk) addr <= addr + 1;
        sramw #(.ADR(ADR)) u1 (.Clk(clk), .Addr(addr), ...);
        endmodule TEST;
        Now this is obviously not complete code, but it gives an idea of what you have to do.
        I've left out how you generate the clk signal, and obviously you need to setup some values at initialization or on reset asserted.
        But the above shows what your 'auto incrementing' address signal needs to look like.
