Auto increment address in the memory in a verilog program
Well, you haven't shown enough code.
In your module definition Addr[ADR-1:0] is an input to the module and thus is a set of wires.
In a higher level module that instantiates a call to sramw() you would probably have declared Addr[ADR-1:0] as a reg.
And in that module you could do assignments to that reg variable, including incrementing it on a clock edge.
Dear Sir/Madam,
Yes as you mentioned the addr[ADR-1:0] has been assigned as input, but the input cannot be declared as a register right, then how to solve the issue.
On a condition @ every posedge clk my address should get auto incremented and in that auto incremented address i have to store some value.
If possible could u please share me a code for this ,Which will be very much useful for me to proceed further.
With Regards,
V.Mathiazhagan
- ak6dn4 years ago
You still need to write the upper level module code that instantiates your sramw module instance.
It would have pieces of code that look something like this:
module TEST; localparam ADR = 9; reg clk; reg [ADR-1:0] addr; always @(posedge clk) addr <= addr + 1; sramw #(.ADR(ADR)) u1 (.Clk(clk), .Addr(addr), ...); endmodule TEST;Now this is obviously not complete code, but it gives an idea of what you have to do.
I've left out how you generate the clk signal, and obviously you need to setup some values at initialization or on reset asserted.
But the above shows what your 'auto incrementing' address signal needs to look like.
