15 years agoAtom X is connected on its PADTOINPUTREGISTERDELAYSETTING port but atom Y is not.
Hi all, first time poster here.
I'm not an Altera guru, by any means, but I've been able to muddle through with the help of Google and co-workers. This error has me baffled, though. I am trying to include a DRR3 phy created by the mega-wizard plugin manager in our design, and I get the following error:Error: Atom "...|ddr3_phy_alt_mem_phy_dq_io:dqs_group.dq.dq_pad|ddr_io_config_gen.dq_io_config" is connected on its PADTOINPUTREGISTERDELAYSETTING port but atom "...|ddr3_phy_alt_mem_phy_dm:dqs_group.dm_gen.dm_pad_gen.dm_pad|dq_io_config" is not connected. Both must be connected or both must be disconnectedNow, I've looked in the verilog (alt_mem_phy.v) created by the plug-in manager, and I've found the ports that it's complaining about: begin : ddr_io_config_gen
// IO_CONFIG - num_dq 0->16
stratixiii_io_config dq_io_config(
.datain (scan_din), // shared per DQS group
.clk (sc_clk),
.ena (scan_enable),
.update (scan_update), // shared per DQS group
// synopsys translate_off
.devclrn(), .devpor(),
.dutycycledelaymode(),
.dutycycledelaysettings(),
.outputfinedelaysetting1(),
.outputfinedelaysetting2(),
.outputonlydelaysetting2(),
.outputonlyfinedelaysetting2(),
.padtoinputregisterfinedelaysetting(),
// synopsys translate_on
.padtoinputregisterdelaysetting(dq_padtoinputregisterdelaysetting),
.outputdelaysetting1 (dq_outputdelaysetting1),
.outputdelaysetting2 (dq_outputdelaysetting2),
.dataout (scan_dout)
endand // IO_CONFIG - num_dq 0->16
.datain(scan_din), // shared per DQS group
.clk(sc_clk),
.ena(scan_enable),
.update(scan_update), // shared per DQS group
.padtoinputregisterdelaysetting(),
.outputdelaysetting1(dq_outputdelaysetting1),
.outputdelaysetting2(dq_outputdelaysetting2),
.dataout(scan_dout)
);So it's pretty clear that one .padtoinputregisterdelaysetting port is connected and the other one isn't, but when I try to disconnect the connected one, the error doesn't go away. Any help on this? Thanks in advance!
