13 years agoAsynchronous Signal
Hi. I have a problem that my FPGA design failing after several seconds. The code purposes isto measurement frequency from external signal generator (50kHz)*. I'm working with 50Mhz clock, LPM_Divi...
13 years ago --- Quote Start --- Using at least 1 register will help; --- Quote End --- It will work in the lab, but will at some time in the future fail, because a 'one stage synchroniser' may not not reliable enough, especially at high frequencies. So it is good practice to always use a synchroniser chain of at least two successive registers. Of course the lower the frequency of the sampling clock the more reliable a 'one stage' synchroniser gets up to the point where the clock period is sufficiently long enough to let every metastable condition settle in time for the next clock edge.
