13 years agoAsynchronous Signal
Hi. I have a problem that my FPGA design failing after several seconds. The code purposes isto measurement frequency from external signal generator (50kHz)*. I'm working with 50Mhz clock, LPM_Divi...
13 years agoWhen an asynchronous signal is fed into an FSM we have two pitfalls:
- difference in path delays: As the single input must propagate to all registers in the FSM it takes different paths and one (or more) registers see the change after the clock edge resulting in an undefined state.
- metastability: Even if all the changes are seen by the same clock edge some register input may fail to meet the required setup time and the register may transit in a metastable state, and the register may or may not reflect the intended change and you can end up with an undefined FSM state as well.
