fst21
3 years agoAssignment RTL_PARAMETER
I use the PLL Reconfig Intel FPGA IP core for Arria 10, which uses one fifo each for data and command synchronization. These fifos are mapped as block RAM in M20K despite the small size of onl...
- 3 years ago
As it turns out, there's no way to change it other than changing the Verilog code.
Most of the reconfig IP in Arria 10 is hardcoded Verilog that Quartus doesn't modify, so you have to directly edit the Verilog as what I did in the previous reply.
Richard Tan
RichardT_altera
3 years agoI will need to consult the engineering team for alternative way to do it. I am not able to success map it to MLAB using set_parameter as well.
fyi set_parameter how-to use:
Richard Tan
