Assignment RTL_PARAMETER
- 3 years ago
As it turns out, there's no way to change it other than changing the Verilog code.
Most of the reconfig IP in Arria 10 is hardcoded Verilog that Quartus doesn't modify, so you have to directly edit the Verilog as what I did in the previous reply.
Richard Tan
May I know does my latest reply helps ?
Richard Tan
Hello Richard,
thank you for your answer.
Yes, the change scfifo_component.lpm_hint = "RAM_BLOCK_TYPE=MLAB"; works. I had already tried this. However, it is not applicable, because every time the IP is generated, this line has to be added manually.
In the article https://community.intel.com/t5/FPGA-Wiki/Using-set-parameter-for-Quartus-compile-directives-in-VHDL-and/ta-p/735134 a similar problem is described. Only unfortunately it is unclear how this would work with a string.
Many greetings,
Fritjof
