12 years agoask about codec 24bit on de2
i want to use this codec for input analog signal, it that ok ???
Yes, if you don't mind the AC coupling.
--- Quote Start --- Yes, if you don't mind the AC coupling. --- Quote End --- when i read about audio codec 24bit on de2 , they said that audio need to connnect with nios II , but i dont farmiliar with nios II, can i just use VHDL code to control the codec ??? - Altera_Forum
Yes, there are also Verilog demonstration projects shipped with DE2
--- Quote Start --- Yes, there are also Verilog demonstration projects shipped with DE2 --- Quote End --- thanks,i will try convert them to VHDL
