12 years agoArrow SoCKit, how to read USB device?
Hi! I have an Arrow SoCkit evalboard, and i have pendrive which is pluged into the micro usb of the kit. The pendrive and linux indicates that they see each other, because the pendrive is blink...
12 years agoYou don't need specific drivers for an ordinary USB thumb drive formatted with FAT32 (as most are). The SoCkit may be seeing your pen drive already. I don't know if this will work on the SocKit, but on a desktop linux system you would type "cat /proc/partitions" before and after inserting the drive. If there is a new line in the output that is where linux put your drive. You can then use the mount command to gain access as usual.
