11 years agoarriaII GX VCCIO
<br> I'm planning to use EP2AGX65DF29C4.<br> I'm designing a power supply.The outline is as follows.<br> BANK3A VCCIO3A=2.5V VCCPD3A=2.5V<br> BANK4A VCCIO4A=1.5V VCCPD4A=2.5V (for DDR3)<br> ...
11 years ago --- Quote Start --- The Bank 3A and 3C is different I/O bank which can be assigned with different I/O standard. Bank 3C and 8C are dedicated configuration banks. You can refer to the Arria II handbook, Figure 6.1 for details: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/arria-ii-gx/aiigx_51006.pdf --- Quote End --- Thank you irish-san,bfkstimchan-san and ah_zhi02-san I attach fitter report. All except for configuration bank are the voltages I intended(2.5V,3.3V). configuration bank voltage is 2.5V. Do I have the way to set configuration bank voltage as 3.3V using QuartusII? I set a power supply of MSEL,conf_done,JTAG etc to 3.3V(By a circuit diagram.). For example through Resistance I connect MSEL to 3.3V. Or isn't it necessary to set C to 3,3V? Should I use 2.5V power supply like a circuit of attachment?
