11 years agoarriaII GX VCCIO
<br> I'm planning to use EP2AGX65DF29C4.<br> I'm designing a power supply.The outline is as follows.<br> BANK3A VCCIO3A=2.5V VCCPD3A=2.5V<br> BANK4A VCCIO4A=1.5V VCCPD4A=2.5V (for DDR3)<br> ...
11 years agoYou can cross check the implementation by running through Fitter compilation. As long as the voltage setting can pass Fitter compilation, there should be no issue. If you do not have a design to test out yet, you can try to create simple design with output pins set to specific voltage and assign to the specific bank. Generally, the bank will be assigned vccio according to the output pin.
