11 years agoArriaII GX Transceivers termination
I am planning to use arriaIIGX(780pin EP2AGX65DF29C4) for HD-SDI reciver. I am planning to use Transceivers(for example GXB_RX0p(AG23),GXB_RX0n(AH23)(reciever)). Receiver has 100 ohm on c...
11 years ago --- Quote Start --- Thank you ,ah_zhi02-san and bfkdtimchan-san I found OCT 100 ohm(reciever and refclk)in fitter report. So I removed external termination(100ohm) from reciever and refclk. But clk* input termination is off. So I put external termination on clk* input(attachment). Best regards, okuyama --- Quote End --- Hi, The refclk pin should support OCT as well. You can try to enable the OCT through Assignment Editor.
