11 years agoArriaII GX Transceivers termination
I am planning to use arriaIIGX(780pin EP2AGX65DF29C4) for HD-SDI reciver. I am planning to use Transceivers(for example GXB_RX0p(AG23),GXB_RX0n(AH23)(reciever)). Receiver has 100 ohm on c...
11 years agoHi,
Generally the 100Ohm OCT will be auto-assigned by Fitter if user does not specify any termination setting. However, it is recommended to double check in the Fitter report. Alternatively, you can manually set it through the assignment editor to ensure the setting.
