11 years agoarriaII GX Transceiver (SDI)
I'm planning to use EP2AGX65.EP2AGX65 has 8 Transceiver channel(use for SDI). Channel names(pin name) are from GXB_x0x to GXB_x7x(X=p,n).Banks are QL0 and QL1 Refclk names(pin name) are REFCLK0...
11 years agoHi,
Sorry as I am not very clear with your inquiries. Are you inquiring how should the following QSF be changed after you change your device? If yes, the TX PLL location is likely to change after you change the device. So, you will need to find out the new TX PLL location to assign to your design. "set_location_assignment HSSIPLL_X0_Y56_N135 -to "hsmc_sdi:u0_hsmc_sdi|A2gxSDI3G_tx:u0_A2gxSDI3G_tx |sdi_megacore_top:sdi_megacore_top_inst|sdi_txrx_p ort:sdi_txrx_port_gen[0].u_txrx_port|rc_s4gxb_tx:gen_tx_alt4gxb.u_gxb|alt4 gxb:alt4gxb_component|alt4gxb_u3q4:auto_generated| tx_pll0" set_location_assignment HSSIPLL_X0_Y59_N135 -to "hsmc_sdi:u0_hsmc_sdi|A2gxSDI3G_ch4:u1_A2gxSDI3G|s di_megacore_top:sdi_megacore_top_inst|sdi_txrx_por t:sdi_txrx_port_gen[0].u_txrx_port|rc_s4gxb_duplex:gen_duplex_alt4gxb.u_ gxb|alt4gxb:alt4gxb_component|alt4gxb_f1g9:auto_ge nerated|tx_pll0" "
