11 years agoarriaII GX Transceiver (SDI)
I'm planning to use EP2AGX65.EP2AGX65 has 8 Transceiver channel(use for SDI). Channel names(pin name) are from GXB_x0x to GXB_x7x(X=p,n).Banks are QL0 and QL1 Refclk names(pin name) are REFCLK0...
11 years ago --- Quote Start --- Thank you bfkstimchan-san,nic_@-san I confirmed that there are Transceivers to the left by a pin-planner. By the way, attachment is a sample source of SDI(It was downloaded from a site of Altera). Description of following is PLL location in qsf file. In the sample,device is EP2AGX125EF35C5ES. But when I changed it to EP2AGX65DF29C4 this time, an error occurred. When changing a device, how should this part be written? set_location_assignment HSSIPLL_X0_Y56_N135 -to "hsmc_sdi:u0_hsmc_sdi|A2gxSDI3G_tx:u0_A2gxSDI3G_tx|sdi_megacore_top:sdi_megacore_top_inst|sdi_txrx_port:sdi_txrx_port_gen[0].u_txrx_port|rc_s4gxb_tx:gen_tx_alt4gxb.u_gxb|alt4gxb:alt4gxb_component|alt4gxb_u3q4:auto_generated|tx_pll0" set_location_assignment HSSIPLL_X0_Y59_N135 -to "hsmc_sdi:u0_hsmc_sdi|A2gxSDI3G_ch4:u1_A2gxSDI3G|sdi_megacore_top:sdi_megacore_top_inst|sdi_txrx_port:sdi_txrx_port_gen[0].u_txrx_port|rc_s4gxb_duplex:gen_duplex_alt4gxb.u_gxb|alt4gxb:alt4gxb_component|alt4gxb_f1g9:auto_generated|tx_pll0" --- Quote End --- I couldn't attach it. I attach again.
