11 years agoarriaII GX Transceiver (SDI)
I'm planning to use EP2AGX65.EP2AGX65 has 8 Transceiver channel(use for SDI). Channel names(pin name) are from GXB_x0x to GXB_x7x(X=p,n).Banks are QL0 and QL1 Refclk names(pin name) are REFCLK0...
11 years ago --- Quote Start --- By the way, it is always recommended to check your placement of transceiver and refclk by running Quartus II Fitter compilation. It will help to check against placement rules. --- Quote End --- Thank you,bfkstimchan-san I have queation of bank location. I attach the question. There are transceivers on the left side in bank diagram. But there are transceivers on the right side in package top view. I believe package top view is right. There is a comment as “reverse view for package” in bank diagram. Why aren't transceivers written on the right in bank diagram?
