11 years agoarriaII GX Transceiver (SDI)
I'm planning to use EP2AGX65.EP2AGX65 has 8 Transceiver channel(use for SDI). Channel names(pin name) are from GXB_x0x to GXB_x7x(X=p,n).Banks are QL0 and QL1 Refclk names(pin name) are REFCLK0...
11 years agoBy the way, it is always recommended to check your placement of transceiver and refclk by running Quartus II Fitter compilation. It will help to check against placement rules.
