11 years agoarriaII GX Transceiver (SDI)
I'm planning to use EP2AGX65.EP2AGX65 has 8 Transceiver channel(use for SDI). Channel names(pin name) are from GXB_x0x to GXB_x7x(X=p,n).Banks are QL0 and QL1 Refclk names(pin name) are REFCLK0...
11 years ago"Can the respective transceivers(8 channels) use refclk0 or refclk1?
Can 1 transceiver choose refclk0 or refclk1? " Hi, There should be no issue for the transceiver channel to select between two refclk. You can do it through dynamic reconfiguration and switch the refclk source.
