11 years agoarriaII GX flash program
By writing JIC file from JTAG connector,I config FPGA. It is follwing route. Jtag connector->FPGA->EPCS serial flash Can I write sof and elf file by flash programmer using the route above-m...
11 years agoHi,
Yes, you can still to program the .sof and .elf files in via Quartus II programmer and flash programmer using the external USB Blaster download cable. The method should be the same when using inner USB blaster.
