11 years agoArriaII GX and SDI MegaCore Function
HD-SDI's refclk frequencys are 148.5MHz and 148.35MHz. I am planning to swicth 148.5MHz and 148.35MHz before SDI MegaCore Function by RTL programming. example) assign refclk=sw? refclk1 : re...
11 years ago --- Quote Start --- By the way, to switch between two data rate, I think you would also need to enable the TX PLL switching in the IP core to allow dynamic reconfiguration for data rate switching. --- Quote End --- Thank you, nic_@-san, To enable the TX PLL, Should I use tx_serial_refclk,tx_serial_refclk1 of SDI MegaCore Function? Is the item TX PLL select/reconfig in dynamic reconfiguration(AN588 page 30)? Please tell me switching method in detail.
