Arria10 SoC Devkit FPGA UART Guide
I choose uart1 and uart0 to the FPGA. I exported the uart signals. Then I connected these signals in my logic. But when I connect the uart port with a serial communication program (like minicom) on computer, i see:
"U-Boot 2014.10 (May 01 2016 - 08:22:23)
CPU : Altera SOCFPGA Arria 10 Platform
BOARD : Altera SOCFPGA Arria 10 Dev Kit
DRAM: WARNING: Caches not enabled
SOCFPGA DWMMC: 0
Fail: read msel=2
FPGA: Init failed with error code -1
INFO : Skip relocation as SDRAM is non secure memory
Reserving 2048 Bytes for IRQ stack at: ffe2db10
data abort
pc : [<ffe00b1a>] lr : [<ffe01d4d>]
sp : ffe3bf00 ip : 0000001c fp : 00000001
r10: ffd02078 r9 : ffe3bf60 r8 : ffe00054
r7 : ffe20b60 r6 : ffe3c000 r5 : 00000000 r4 : ffffd000
r3 : ffcfb000 r2 : 00000002 r1 : 00000001 r0 : 00000001
Flags: nzcv IRQs off FIQs off Mode SVC_32
Resetting CPU ..."
I don't get it. I don't send this messages. If I routed the uart0 and uart1 to FPGA and if I don't send these messages, who can access the uart port and send them? If the hps send them, then I couldn't routed the uart to fpga. How can prevent it or connect the uart to the fpga in right way. Addition to this am I gonna do pin assignment for the exported uart signal, or the hps ip automaticaly do it?
