10 years agoArria10 HPS Fpga to Sdram cannot be configured above 64 bits
Hi All,
I want to use the fpga to sdram path in Arria 10 HPS. I want to connect a 256bit AXI interface operating at 125 Mhz from a third party IP to this port. I had a couple of questions:- I cannot select a 256 bit data width in HPS parameter editor. The maximum I can go upto is 64bits.
- If I want to work with 64bit data port but still match the bandwidth (32 Gbps = 256 bits * 125 Mhz) of third party IPs AXI interface, how can I really do it ?
- How do we decide the frequency of the clock for this fpga-to-sdram port.
- Which DDR protocol will QSYS configure in the DDR controller. Will it be DDR3 or DDR4. How does Qsys decide this anyway?
Lars_g,
Thanks for the reply. Actually I am working on Arria10. When I instantiate a HPS component in Qsys, it does not have any options related to the DDR protocol or the DDR memory width like it has in Arria 5 (under SDRAM tab. The only option it gives me is to enable a conduit to EMIF. 2. You are right. In arria 5 or cyclon 5, you can have a width of upto 256 bits for Fpga-2-HPS-Sdram port, but in Arria10 the maximum width available for selection is 64 bit AXI. In Arria5 or Cyclon, you don't have to manually instantiate the DDR PHY, but what I am thinking is probably in Arria 10, I will have to manually instantiate the external memory PHY. Probably that's why, when I instantiate HPS, its parameter editor does not have any option related to DDR protocol or DDR memory width selection. Now, my real problem is, if I have only 64 bit AXI interafce to the HPS(FPGA-2-HPS-SDRAM interface), I will have to clock it at 500 Mhz to match the bandwidth of my master port(coming from a third party IP 256bit @ 125 Mhz). I am very uncomfortable with such a high frequency(even though this path is really in a hard IP). I don't understand why I cannot have a 256 bit port to HPS sdram interface like I can have in Arria 5. Why altera is limiting bandwidth on this fpga-2-sdram interface to the HPS!!! Let me know what you think. - Altera_Forum
do you use qsys to configure your HPS? you have to add a HPS component
in this component are parameter for ram width and ram protocol as far as i know, hps ram can be up to 64 bit and you can add a fpga-to-hps-interface axi interface with up to 256 bit width don't mix up ram data witdh and axi interface width i use cyclone v fpga to hps interface with 150 MHz, Arria 10 should be more powerful
