Yamada1
3 years agoArria10 Embedded Memory
I have a question about Embedded Memory. I plan to use Arria10's M20K block RAM with 2-Port RAM.
In figures 1 and 4 of the user guide, the input signal to the RAM block transitions at the falling e...
- 3 years ago
Check out this document link https://www.intel.com/content/www/us/en/docs/programmable/683240/17-0/about-embedded-memory-ip-cores.html (Page 41) onwards, the Design Example may be can help you as well.
Sheng
FvM
3 years agoGenerally, timing analysis will take care of sufficient hold time. You'll notice that maximal A10 block RAM clock frequency is rather high, e.g. > 500 MHz. Respectively you can expect a low hold time requirement, probably < 1 ns.
Yamada1
3 years agoMr. FvM
Thank you for your answer.
It was very helpful.
