vivekt
6 years agoArria10 DDR4
We are planning to design a Board with 10AX057N
One of our requirements is for the FPGA to support 2 separate SODIMM channel with 64bit Data,64Gbit memory. Kindly confirm if the Arria10 will support the above requirement
- Rashmi1
HI Vivek,
Please refer to EMIF sec estimator: https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/external-memory-interfaces-support/emif.html
Plug in Device family, Speed grade, interface type, memory standard, clock rate etc or the available data you have and submit. Spec estimator will be able to provide you the information you are seeking.
Intel Forum Support
- vivekt
Is there any option to select 2 Independent SODIMM in the link
