11 years agoArria10 ddr3 sodimm example design
Hello everybody,
I have 2 questions regarding ARRIA10 DDR3 SODIMM EXAMPLE DESIGN. 1. I have generated an example design for ARRIA10 HARD MEMORY DDR3 SODIMM and simulation takes 100usec (modelsim is running for 12hours) until I see the DDR data transfer in the modelsim. I've disabled the calibration so it doesn't do calibration. I found it hard to believe its i'm using ALTERA's Modelsim ? (by the way, with xilinx IP - VSIM it takes a few seconds). Do you have an Idea where is the problem? 2. I can't find a detailed documentation about the example design - test bench etc. Can you please assist? Many thanks !:)No RepliesBe the first to reply
