scong5
6 years agoArria10 , Error by use Generic Serial Flash controller
Hi I generate a Generic Serial Flash controller refer to the "Generic Serial Flash Interface Intel FPGA IP Core User Guide" . It sucessed after Generate HDL . But faild at "Processing ➤ Start ➤ Sta...
JohnT_Altera
6 years agoHi,
It looks like the generated file is hitting the path limit. Could you reduce the file name of your project and the IP? Windows only support 256 character for the total path including file name. (https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/fb74100.html)
If you are still facing the issue then I would recommend you to use Linux system.
