12 years agoArria V SOC clock sources
Hello. I created a sample project (simple verilog code) in Arria V SOC dev board. The design needs a clock, but I can't seem to get the right clock source from the multitude of available clock sou...
9 years ago --- Quote Start --- I believe the installation zip here: https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arriav/arriavst_5astfd5kf40_soc_v15.1.0b185.zip should have a "golden_top" folder (or something like that) which has all the pins on the board defined (with the correct pin location) --- Quote End --- ---------------------------------------------------------------------------------------------- Certainly, this contains all the appropriate files to start with the "bare-metal" design, or you may also check in Google: bare-metal gold designs. :) -- Alex
