12 years agoArria V SOC clock sources
Hello. I created a sample project (simple verilog code) in Arria V SOC dev board. The design needs a clock, but I can't seem to get the right clock source from the multitude of available clock sou...
9 years agoWhat I mean is to open up the Quartus project (.qpf) located inside the golden_top folder. If you open the pin assignments within the project, it should have all the pins defined. In that way, you can just edit on top of this project (re-use the same pin name in your design file).
