12 years agoArria V SOC clock sources
Hello. I created a sample project (simple verilog code) in Arria V SOC dev board. The design needs a clock, but I can't seem to get the right clock source from the multitude of available clock sou...
9 years ago --- Quote Start --- Hello, I too came up with similar need of knowing clock pins. Is there any manual, excel file or any other file where we can get all the pin assignments? Thank you all in advance. Regards --- Quote End --- I believe the installation zip here: https://www.altera.com/content/dam/altera-www/global/en_us/support/boards-kits/arriav/arriavst_5astfd5kf40_soc_v15.1.0b185.zip should have a "golden_top" folder (or something like that) which has all the pins on the board defined (with the correct pin location)
