12 years agoArria V SOC clock sources
Hello. I created a sample project (simple verilog code) in Arria V SOC dev board. The design needs a clock, but I can't seem to get the right clock source from the multitude of available clock sou...
12 years agoAre you using the Arria V SoC Development Kit, do you could be help me i have an issue trying to set-up the Arria, appeared the LED in Red of MAX_ERROR.
When you started to work with the Aria doesn't happened this issue to you. Thanks, Alex.
