12 years agoArria V SOC clock sources
Hello. I created a sample project (simple verilog code) in Arria V SOC dev board. The design needs a clock, but I can't seem to get the right clock source from the multitude of available clock sou...
12 years agoSo you have a user logic design that you are attempting to use HPS EMAC clock pins with? Those EMAC clock pins wire up to the EMAC core in the HPS and are *not* available to the FPGA so if that was your intension you should pick an FPGA clock instead.
