JOter's avatar
JOter
7 years ago
Arria V-Quartus 18/18.1 time quest constrains.
I have problems, with a Arria V-Quartus 18/18.1 and time quest constraints. It seems quartus does not apply the constraints file. The same Project Works properly with a cyclone III and Q13.1.
  • JOter's avatar
    JOter
    I send you both projects, so you can obtain all information.
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    Can you check if the constraints are being ignored under 'Ignored Constraints'? Can you provide the timing report for both design?
    • JOter's avatar
      JOter
      There are not errors. The problema is that the signal are delayed as spected.
      The signal re: RAM_CLK (CLK) and OUTPUT 0 (counter)
      We tested both signal in one scope, and we didn't notice any change between them changing the OUTPUT_DELAY constraints.
      Remenber we checked it also using a C III, and in this case we got the spected signal.
      We used the next constrains commands:
      set_output_delay -clock vt_RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
      set_output_delay -clock vt_RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
      And
      set_output_delay -clock RAM_CLK -max [expr $RAM_tsetup + $RAM_BDb_max - $RAM_CLK_DLY_MIN] [get_ports {OUTPUT[0]}]
      set_output_delay -clock RAM_CLK -min [expr -$RAM_thold + $RAM_BDb_min - $RAM_CLK_DLY_MAX] [get_ports {OUTPUT[0]}]
      Best regards
