11 years agoArria V interfacing LVDS 2.5 with 3.3V reciever
Hello, I just wanted to check if there are likely to be any problems interfacing the following clock fanout ( http://www.ti.com/lit/ds/symlink/sn65lvds104.pdf ) which is 3.3v with 2.5v IO on th...
11 years agoHi rmawatson,
When interfacing the Arria V LVDS output with other receiver, you would need to ensure the VCM of the LVDS buffer still within the specification ie 1.25V. If out of the spec, then you might want to consider using AC coupling to reconstruct the VCM to meet the specification to avoid any issue to the device.
