bansarth
6 years agoArria V GX ethernet connect causing router issues
Hello, I am running the AN647 Reference Design on my Arria V GX, and whenever I plug the FPGA into my router, and it is just listening for packets to be sent, all other devices on my routers ethernet...
SengKok_L_Intel
6 years agoHi,
I assume the AN647 design's ethernet link is still up after connecting to the router, if this is the case, you might need to check the routing setting if there is any security setting that may cause the problem.
Regards -SK
