8 years agoArria V GX - Clock problem
Hello!
I just started with the Altera FPGAs and Quartus II, I am learning but I haven´t could do work my first sequential example. I have tried a combinational design (a switch with a led) and it work perfectly. In contrast, in the sequential design I can´t make the clock CLK work. I have correctly defined the pin assigment but I don´t know if I have forbidden something about this assigment, I attached a picture with the assignment and the sequential example it is a blinking led. The VHDL code it is very easy and short: library IEEE; use IEEE.NUMERIC_STD.all; use IEEE.STD_LOGIC_1164.all; entity BLINKING is port(CLK, RST: in STD_LOGIC; LED: out STD_LOGIC); end BLINKING; architecture FUNCIONAL of BLINKING is constant c_fin: natural := 50000000; signal CUENTA: natural range 0 to 2**26-1; signal LEDi: STD_LOGIC; begin process(CLK, RST) begin if(RST='1')then CUENTA <= 0; LEDi <= '0'; elsif(CLK'EVENT and CLK = '1') then if(CUENTA = c_fin - 1) then CUENTA <= 0; LEDi <= not LEDi; else CUENTA <= CUENTA + 1; end if; end if; end process; LED <= LEDi; end FUNCIONAL; I compile all the project and I only obtain one warning message, it say: warning (15714): some pins have incomplete i/o assignments. refer to the i/o assignment warnings report for detailsWhat other assignments should I make to theses pins? I have also created a file *.sdc with clock constraints, the content is as follow: create_clock -name (clk) -period 20.000 -waveform { 0.000 10.000 } [get_ports {clk}]
I am working with the development board Arria V GX starter kit, and the clock that I am using is the CLKIN_50_BOT that has a frequency of 50MHz that connects to the AP29 pin. Can someone tell me what I need to make my blinking led example work? Thank you for all and best regards :)
1 Reply
Refer the thread which address the issue in detail. https://alteraforum.com/forum/showthread.php?t=5112 Give slew rate in pin planner to eliminate the warning. Let me know if this has helped resolve the issue you are facing or if you need any further assistance. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
