11 years agoArria V 1.5v PCML Read
Hi, I would like to use signal tap to read the value on a number of 1.5v PCML pins, however, using signal tap to probe these pins causes an error stating that the pins must have a fanout of 1. ...
11 years agoHi,
The PMA does not have a specific protocol to serialize or deserialize data. Basically what it does it convert the parallel data to/from serial data based on your configuration ie data width, data rate.
