11 years agoArria V 1.5v PCML Read
Hi, I would like to use signal tap to read the value on a number of 1.5v PCML pins, however, using signal tap to probe these pins causes an error stating that the pins must have a fanout of 1. ...
11 years agoThe Arria V GT device that you are using should support the transceiver IP ie Native PHY, Custom PHY to allow the usage of the transceiver pins.
