12 years agoARRIA V 1.1VCC issue
Hi, I have designed a new board for my company based on a 5AGXMB1G4F31C4N. When I received the board, I checked isolations between all the power line and GND. I got a 35Ohm isolation betw...
12 years agoIt doesn't sound like you have a problem. If you can configure the FPGA and perform the tasks you've stated then a lot is working properly.
35Ω is a perfectly reasonable DC resistance to measure between VCCINT and GND on an assembled board. What were you expecting? A quick check on some boards I have around me reveals DC resistances as low as 20Ω between VCCINT and GND. They all work as expected. Cheers, Alex
