13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
11 years ago --- Quote Start --- Hi arvindk, we solved the problem by using a gap-filler between heat-sink and chip. If you would like more information(our solution, application notes...) I can give you via email. If you can, write me a email address. --- Quote End --- HI~ joey1。 I have the same problem with EP2AGX45。We have 10 PCBA board total,now 3 boards' VCCA_PLL(2.5V) VCCD_PLL&VCC(0.9V) is Micro-Short to GND(Blow 1ohm)。and some PLL can not work normal。 what is your email? my email address is [email protected]
