13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoHi arvindk, we solved the problem by using a gap-filler between heat-sink and chip. If you would like more information(our solution, application notes...) I can give you via email. If you can, write me a email address.
