13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoHi Joey, yes we are using heat-sink with push pins from AAVID (10-5607-05G). we are also using lidless FCBGA package, and its bottom right is damaged. So this could be the reason. we will be sending the FPGA to Altera Failure Analysis Center soon. We replaced the FPGA and now its working. our board was proto board and we had removed the heatsink couple of times.
