13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoHi we use,
Ferrite bead Chip 33 ohm @ 100Mhz as PLL supply filter. can you see your FPGA board power rail voltages and IC used...??
