13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agohi,
we are using linear power supply, and its with in the range.there is no overshoot. chances of ESD is less in our case. what type of filtering you are using for pll supply? regards, Arvind.
