13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agoHi,
Yes as per RMA result FPGA IC is prone to overshoot of supplies. And as per my analysis, There could be two reasons one Overshoot \ Voltages on rail out of tolerance (Eg:- 1.5V vccb could be 1.425 - 1.575) and other cause may be ESD.......
