13 years agoArria II EP2AGX45CU17C6N power up failure.
Hi all, I am using Arria II EP2AGX45CU17C6N FPGA in my PCIe interfacing card project, I had only one FPGA device mounted on PCB and power section. Power voltage rail on PCB board ...
13 years agohi
have you found the cause of FPGA's PLL power pin shorted-circuit to GND. we have same problem in 2 of our boards. we are using EP2AGX95EF35C4N. VCCA_PLL pins are shorted to GND. Regards, Arvind.
