JCass5
8 years agoArria 10 will not load from Micron MT25QU256 PROM
I am using an MT25QU256 PROM to program an Arria 10 10AX027E4 device. The MSEL setting is active serial standard power on (011). The programming voltage is 1.8V. It appears that the access to the PRO...
Nooraini_Y_Intel
7 years agoHi Jim,
Apologize for the delay in response. It's good to know you are able to resolve the issue and move forward with your design and we will take note on your feedback. At least you were able to identify the root cause due to the incorrect .sof file being selected in the .cof file and resolve the issue. This information will be benefit for other users if they encounter similar failure.
Nooraini
