Arria 10 (speed grade 3) has worse timing performance than Cyclone 10 GX (speed grade 5)
- 4 years ago
As confirmed by @RichardTanSY_Altera , this is expected behavior. Although it is totally baffling that a more expensive device family, combined with a superior speed grade leads to worse timing performance, I am satisfied that my question has been answered.
As mentioned in the user guide, it seems that it is expected when you find the A10 with speed grade 3 is worse than C10 speed grade 5.
Btw, is the timing failed at all corner?
Do you mind to share us the design for further investigate?
- hcom4 years ago
@RichardTanSY_Altera If this is expected behavior, then there would be no sense in addressing your two questions. Wouldn't it just be a waste of time?
Also, my past experience with Intel employees on this forum is that they ask me to provide a project, I spend hours removing sensitive information and uploading the project, then they never bother to look at it. You can easily create your own project. It doesn't seem to matter what is in the project - timing behavior is significantly worse in the more expensive device.
