Arria 10 SoC EMIF Input clock jitter requirment
Thank you for your reply
I know the jitter performance of my reference clock. I have a datasheet for it that states it clearly.
I am trying to understand what the requirements are to make sure that my reference clock is adequate.
Could you explain what are the jitter requirements for the reference clock? Where do these requirements come from? Are they written in some spec.?
Are the jitter requirements dependent on DDR4 data rate?
Hi
Jitter amount affects the timing margin in the IP. If the reference clock has more jitter than requirement there may be malfunction on the IP due to the timing issue. The jitter requirement is consistent regardless any DDR4 data rate.
- TSege15 years ago
For Arria 10 I use LVDS 133MHz as reference clock for the DDR4 controller with 0.37pSec typical RMS jitter (Integration over 0.1MHz-20MHz frequency band)
The spec for the Arria 10 as defined in Intel EMIF Arria® 10 FPGA IP User Guide, page 205 is 1.22ps at 1e-16 BER , Identifier: PHY_DDR4_REF_CLK_JITTER_PS.
Please advise if OK
tamir,
- yoichiK_altera5 years ago
Contributor
Hi
Your reference clock jitter should be no problem to the Arria10 reference clock jitter spec.
