SB_S
7 years agoArria 10 SoC 10AS016 IO level
This series doesn't support 3.3V of IO . Instead of 3.3V , it supports 3V . Can we still connect the 3.3V signal to FPGA and does it capable of driving 3.3V ?
SreekumarR_G_Intel
7 years agoI believe you are talking about VCCIO supply , if so .. , it is not recommended to use the 3.3V on this rails as per datasheet. you can connect these pins to 1.2V, 1.25V, 1.35V, 1.5V, 1.8V, 2.5V, or 3.0V supplies, depending on the I/O standard required by the specified bank..
Refer below link for more details (Supply pin section - Design guidelines from Intel.
Thank you ,
Sree
SB_S
7 years agoIF we have the device which supports only 3.3V , can we still connect these device IO to FPGA with VCCIO 3.0 V ? Is it is 3.3V tolerant ?
